Fuel system discussion
Lukas64
Has any one ran spartan tuning on a higher hp setup? Such as keep stock appearing turbos (jr high powers) either the ii dragonfire or dual fuelers and 110hp tips. Thanks for any advice
KennySam
I don't have the funds to duals and pistons this time around, I will be doing Marty's kit, deleting the fuel bowl and running 15% nozzles.
LIFE MISSION
B585Ford
WV
LIFE MISSION
I should have my truck back in the next few weeks with that exact setup on the fuel side. PM later if you want to know how it does.
woodsman
Attempting to resurrect this, does anybody have info on how 15% nozzles and stock HPFP ran? Or with a modded pump such as dragon fire or the new x16 from Industrial Injection?
B585Ford
WV
It ran good, especially at lower RPM. At the very high end I did start dropping a little (about 2k rail pressure IIRC) on GH race tune. Even the 15% nozzles did raise the EGTs, especially at low to mid RPMs. Once 59/76 lit, I didn’t see too much hotter temps. I can’t say I felt the power drop even when I did lose a little RP, but I assume I did leave a little on the table.
woodsman
Has anybody tried the new Industrial bored or stroked HPFP? Any dyno results out? Searched google and FB but didn't see much. Thinking the bored version with stock injectors would be pretty entertaining with the right turbo setup...
Jonnydime
But a healthy stock pump will keep up with stock injectors all day.
Purebredtrimmer
Blanchardville WI
I have the Industrial 33% modded with stock injectors. MPD S364.5 SXE kit and piping. Custom mcc tuning for this setup but something’s not right and of course now nobody will even talk to you since the EPA throwdown. This is on a 6.7 though
