New Intake Manifolds
01platinum
Willis, Tx
Wow that's looks freakin awesome. Interested to see how everything will mount now. Keep the pics coming.
Sent from my SPH-D710 using Tapatalk
Chrisf97305
Salem Or
Well got it running tonight. She is so strong with the stage 2 injectors in it. Can't Waite till I get my new injectors from Mike at Farmers. More fuel = More power. Got to love it. Once I get the air filters next week will be taking more pictures.
If we get some sun tomorrow will take some pictures then. The gray just does not show up in the garage.
Chrisf97305
Salem Or
New pictures. Still needs paint and have my new air filters coming. But here it isl
Chrisf97305
Salem Or
Looking good, that is a lot of lines running every where lol
Both turbos run through the front intercooler right?
your right. both turbos go through the front intercooler and then into the water to air on top the engine.
Wanted to use hard lines instead of rubber.
7.3psd97444
Indiana
Hard lines look SOOO much better, and look very professional IMO. Plus they are a little stronger. Looks awesome man, cant wait for a vid.
Chrisf97305
Salem Or
Well at this time I said hell with air boxes. So here is a few pictures of the new air filters that I will be using. The air filters are from Spectre, good looking air filters, thays why I am using them. Needed some color under the hood.
Now its time for the interfenders. I am going to try and start with a trailer fender. Going to cut the hell out of it to get it to fit. Still the best way I think.
7.3psd97444
Indiana
Thanks
I have put about 250 miles on it so far and no issues. Should have my new injectors some time next month. This will be 1 fun truck to drive. Love the looks and the sound of the side pipes but she is LOUD.
Whats the specs on the new sticks? Im just really curious I love this biuld. If you want to you can Pm me.
Chrisf97305
Salem Or
If I did not want to run it on the street then I would be doing something like 350-200's or something like that. This is a street truck. I hit 450 with 230-stock and a bad tune. So with these and a good tune I should see something around the 500 to 525hp mark. With water maybe some where around the 550 575, with nitrous should be over 600 or so. Thats where I want to be. I don't want to spend the money to build a bottom end to handle 800 or so, at least not now. I think that I am on track to make it happen. This should be a real fun truck on the street. I won't be the top dog at the pulls or the fastest on the track, but it will be fun to watch.
and best of all its all mine.:ford:
Chrisf97305
Salem Or
They are still in the works. Been busy with work. Not much time to work on them. Will see how much I get done this weekend. Will post some pictures is I get a chance to work on them.
Chrisf97305
Salem Or
Here is a fender update.
Have it in rough form. The sheet metal is bolted to the fender first. Then the back half witch is the wire is bolted up. I still have some wire to weld in and then cover it with fiberglass. Then when its all done it will be covered with bed liner.
The back part to the fender will also be made out of sheet metal.
The interfender will completely cover the turbo. This should look good. Then If I want to show off the turbos I will just remove the back half of the fender.
