04 Motor Part out
Agjake11
Rosenberg TX
finally got my spare motor torn down and the parts i needed off. the rest is now for sale. its an 04 6.0 with blown coolers and HG's. block should be useable but needs to be machined as there was water in the cylinders and it has been sitting for a while. the bottom end is still complete but if needed it can be disassembled.
parts not available - FICM, Injectors, Intake Manifold, Heads and y-pipe.
all other parts are available and no real pricing set so feel free to make reasonable offers.
manifolds, rocker boxes, hpop, turbo (core), glow plug module, up pipe, ac condensor, fuel bowl, egr valve etc
Agjake11
Rosenberg TX
Update on parts not available - FICM, Injectors, Intake Manifold, oil filter and fuel bowl, turbo, hpop, Heads and y-pipe.
Agjake11
Rosenberg TX
im not sure what they changed on the cover and when. i can get you the cover i have for fairly cheap unless you know one way or the other.
Duece
Tulsa, OK.
Not sure what year motor you have but the cutoff date for the old style oil cooler cover is 3/18/03 (serial numbers 52777 and lower). Can you email me a picture of the turbo oil feed line and its connection to the oil cooler?
Agjake11
Rosenberg TX
updated parts sold: FICM, Injectors, Intake Manifold, Heads and y-pipe, rocker boxes, oil rails, valve covers, oil filter base (not top of oil cooler cover), hpop cover, hpop, turbo. engine harness, oil filter sleeve and fuel bowl and one set of rocker arms and rods.
