whats wrong with my friends truck! idles and wont go
moto613
LAKE FOREST CA
friend has a 01 with the 6 speed has about 186000 miles on it just got new clutch and full service, but the check engine light sometimes comes on when your at a stoplight and the truck wont go over idle. the dealer said they drove the truck and they could not get the light to come on. it comes on and off here and there in mostly stop and go traffic. but it does do it when your on the freeway and get on it but not all the time. seems like when your lugging it ,thats when it happens.
the truck has a dp tuner and a southbend clutch
could it be the cam sensor
sniper_101
rural SK
Isn't there a mildly common issue with these trucks having something to do with the harness for the TPS wearing through/shorting somewhere? I'm sure I read it, but can't remember if it applied to manual trans trucks. Just a thought.
BigAlsPSD
Pea Ridge, Arkansas
Sounds like the IVS(Idle Validation Switch) is not making contact, this on an '01 I'm not sure if it is a separate switch or not, but I personally remove the pedal assembly clean and spray with electrical cleaner annually.
01PSD
Smithfield, NC
I pressed the tow/haul button one time and blew a fuse... all gauges quit working, truck would do nothing but idle.. yeah it sucked
BuckedUp154
Ann Arbor, MI
This happened to me and turned out to be my TPS. Also when crossing railroad tracks, or anything that gave the truck a good shake, the SES would illuminate and truck would die. Awesome right?
perfdiesel
green bay wi
what code is it? if the throttle goes to idle with no throttle response check the wire harness by the drives side shock tower in the front they rub threw there- if ok what code do you have?
