Wheel/Tire Tech Thread
Viking
Minnesota
2wd f250 with a 2 inch level( really only Got about 1.5")
20x10 xd diesel wheels 4.5 backspace
305/50r20 cooper tires (32x11)
No rubbing whatsoever.
I want my 4x4 to sit like that!
SouthFlstrokin'
I dunno I'm prob going to keep this stock. But its so cheap to mod. Then I've Got my buddy that's Got a 6bt and 1ton axles sittting in his shop :evil:
But I would hate to undertake a project like that on my DD
SouthFlstrokin'
But if I lift it 6in and throw it in 35s it'll be on one of these 4 wheels
^^^^^ so much cheaper
I like the fuels the most though ...
I like the american racing.ones.buddy! Black with polished lip. Get a cam for 300 I-6, get the head shaved, and put a valvetrain in it, a header and you'll have a torquey beast to.drive.around.for.maybe 1500 bucks.
02greyduty
Northwest Indiana
i started reading this thread and just had to join this forum. its awesome and such amazing trucks. And some amazing information that im curious to obtain from anyone. i got an 02 f250 with a 6" spring lift and wanna run the biggest and widest wheel setup possible, i love the wide tall stance it looks so bad*$$.
this is my truck as it sits now.
UPINSMOKE
Dundalk, Maryland
Widest and tallest for 6" lift is probably a 22x14 and a 37x15.50 or 13.50 tire
I did 40x15.5 on 16x12s on a 6" lift.
The 37 is probably "ideal". I love my 35s though. If I wanted something.wider Id get a 36x15.5r20 maybe on a 14" wheel. 37s are the point where the tires feel like a.huuuge drag. Cuz they are.
itsallinthestroke
Lafayette Indiana
I've got 10 in wide rims and I'm running 285/75r16. What is the widest tire I can run with a stock suspension? I wouldnt mind going shorter but I like the way this size fills the wheel wells.
UPINSMOKE
Dundalk, Maryland
Depends how much you want to trim the inner fender liners. I have a 12" wide rim with 13.5" wide tires (325/50r20). I did have to trim the driver side fender well to stop rubbing. Completely stock suspension, doesn't rub leaf springs.
ZacPSD60
Spring, TX
@6.4psd916
@SPARTAN
Do you know the weight rating or the part number for the 5.4 coils you used? Throwing around a few ideas of what to do but need more clarification.
B.Warning
NE Missouri
Okay so I'm wanting run 20x12 Moto metal 962's with a 35x12.50 tire. The offset offered is a -44mm I'm doing a 2.5" leveling kit with a 350 block in the rear on my 07 f250... Will these wheels work or am I gonna have to go 4" of lift?
They'll fit just fine with a little trimming. I ran that setup for a little while.
B.Warning
NE Missouri
2.5" spacer with 1"tei spacer 7" block. 22x12.25 alcoa super singles -50 offset 37x13.50x22 Toyo m/t's
2.5" leveling kit. Stock rear 20x12 xd armors 35x12.50x20 federal m/t's
