windrunner408
- Joined
- Jul 27, 2011
- Messages
- 1,496
- Reaction score
- 0
So I think I am going to replace my factory fuel pump with an A1000 so I can flow LOTs of fuel to my injectors. This past Saturday, when my truck was on the dyno, my fuel pressure at 64psi at idle would drop to 50psi at WOT. I realize that this may not constitute absolutely needing an A1000 but my question is, if I do go this route, do I have to change out all of my lines from the tank to the motor?? Or can I just use the lines that came with the AD150 to connect to the A1000 and then just run new lines from it to the motor?? I am thinking that since the AD150 already supplies 150gph and the A1000 only flows about 95gph (significantly less than the AD150) that the 1/2in line from the AD150 will be just fine.
If I have to change out the lines, what size pipe threads go into the AD150??
