Anyone using Beans 300cc injectors ?
Smokin 6.0
Indiana
I had 200cc swamps injectors with a full fuel system and a GTP38R charger in my 02 and they werent enough.. Thinkin about Beans 300's and a H2E charger any input ?
Groomzybanshee
St Joe mo
Beans sell full force injectors . I have there 250s now an use to run there 250s in the puller... Good injectors.. 300s are to big for an h2e.
Fl Stroker
I would contact Dave at Swamps and send him your 200's and have them made into 300's. I am sure it will be worth your time.
co04cobra
WV
Im running Full forces/beans 300/200s. They have done very well. Contact beans and talk to them about their line of injectors available. There are a few other options. Just installed 230/100s from tim a P.I.S in my obs truck.
jwlandry
S.W. Louisiana
I will be going with P.I.S injectors
DocBar
Akron, Ohio
With the right tuning, you should be just fine if you have the supporting mods in place. A lot of people don't recommend live tuning for a "known" setup, but my limited experience has shown me that live tuning is the way to go.
motionmanjcm
I may be wrong but i was under the impression that 238cc is the biggest you want to go with the 38r
Smokin 6.0
Indiana
just want a competitive street truck don't mind usin a 38R but I want to be competitive and I know I'm limited on injector size then.. what y'all think ?
DocBar
Akron, Ohio
My advice would be to buy bigger than you think you need and get good, custom tuning. It's a lot cheaper to change your tuning if you upgrade than having to buy bigger injectors.
That'll give you a nice street truck that has room to grow if you want to. I'd do the 300/200's in a minute. Have you decided on a tuner yet? Again, I definitely recommend live tuning if you can swing it.
Lowdown89
Travelers Rest , SC
I'm running 250/200s on a 38r and make around 550hp seen a high of 566 most pulls its in the high 540 range... I'm not saying the 38r will be happy about doing it for a long long time but it works and spools pretty much instantly
motionmanjcm
I figured there were some exceptions here and there.. I guess 238's would just give you a little more reliability with a 38r than 250's or bigger
chris1978
Kamloops BC Canada
:whs:
Will 250's be ok with a H2E I'm gonna pull it and want to be competitive but it's still a street truck
You can always get your H2E modded as well.
Tuning is key. I'm running 300/200's on a 38R and it drives like a stock truck until I turn the chip up.
DocBar
Akron, Ohio
Tuning, tuning, tuning. Take my set up for example. I have over 550 available, but I asked Matt to detune it for longevity and reliability. That's why I only have 500hp on the dyno at PHP's.
I have no doubt Matt could do the same for just about any size injector. It would take a bit more to get it dialed in with largewr injectors, but it's doable.
