What brand studs and gaskets?
stroker63
I am going to be doing a head stud install soon on my 08 6.4. What brand studs does everyone recommend? Should I invest in OEM head gaskets or look at aftermarket? What other gaskets will I be needing seeing as I will be doing this myself. Even if the heads look good, should I have them milled just to be safe?
powerstrokin15
Charleston, WV
OEM gaskets and ARP studs are what we use. work great. defineatley get the heads checked and machined. I can get you prices on studs and gaskets if you'd like.
Eric@HolderdownPerformance
Newark, DE
haven't done the studs and gaskets yet on mine so I'm no real help there, but on the heads id have them checked just to make sure. Last thing you want is to get it all back together and find out that they were damaged and have to take it back apart.
08BIGRIG
WI
Arp headstuds and stock OEM gaskets. I would have the heads checked for cracks and flatness. U don't want to have to do gaskets twice.
Mike@MPD
Pasadena,MD
Definitely arps I've had mine in for 10k + running 100 psi and beating the hell out of it
Sent by my Nexus powered by this (╯°□°)╯
devdiesel
Barrie, Ontario
I was told last week by a vendor that they do not recommend retorquing arp's if heads have to come off for whatever reason.. how many people have done this? have their been many failures doing this and if so what torque spec are they failing?
Pizza pig
In the Brig (Banned)
MD
mine are on their third, APR says up to 5-6 and then they should be thrown away.
02blue
Slidell, LA
The third time I did my lightning heads, the ARP studs stretched, Installed new ARP's been running strong for about 10,000 miles, my lightning only see's about 22 lbs of boost
