Got a new project
madman1234509
mayfield, ny
Yes. I need to get rid if first gear. From what I can tell in only about one truck length and it already needs to shift.
I wouldn't say the Trans was overly happy with the power... But it's a 2 year old elite stage 1 that Tadd built for the Dpc... It owes me nothing. Old billet input and a standard suncoast converter
Probably going to work with Tadd and use a PCs to make it a three speed...my big turbo likes a load
Data logs were interesting
77 max boost
82 max ebp absolute
30 max boost from the big turbo
Damn happy with that
Those numbers look pretty nice! Would you expect the larger turbo to make a little more boost and the small one a little less? Wasnt quite sure what youd expect the large turbo to make compared to the small one. I cant believe your stage 1 is holding up so well, thats good to hear for sure. Are you logging boost data with the big turbo or just watchin a gauge? Curious to know if you were logging it on the sct or whatever youre using?
Erikclaw
Central CA
I am pretty sure he is logging boost off of both turbos with the DD.
Those are nice boost #'s. Didn't know you were seeing upper 70's. Nice bp and you got the big turbo working for sure to get 30psi out of it.
Administrator
i got mine down to 7920 with me in it (200 lbs) no tailgate spare rear tray lowered 1/4 tank , but i have a sun roof and those add 100+lbs iirc.
madman1234509
mayfield, ny
Thats right, wasnt someone selling a map sensor or something that plugged right into the DD so you could monitor more than one boost reference?
Erikclaw
Central CA
Yeah it is an extra sensor and harness that plugged into the DD. Dustin was doing the mod, not sure if he still is.
Administrator
Dustin builds them I sell them. We can monitor lpfp, rear diff temp , lots of stuff.
madman1234509
mayfield, ny
Can you only monitor 1 with the DD or can you do multiple at once. When I do my build, id like to have gauges for the lift pump pressure, psi for each turbo.... Just to name two I cant read on the DD. Do you have a link or site with info on this?
Erikclaw
Central CA
Look at No Limits vendor page or contact Mike D, he will set you up. Yes you can monitor both turbos at the same time. That is how I have mine set up.
the more boost the big turbo can make the better for sure, i feel like 30 is pretty good tho for what its doing, i may try changing the gate settings to make that happen.
Yes all of the data logging is done on the dashdaq
Does the secondary have a wastegated housing or is it externally gated? If either what is the gate set at?
Garrett
encrypted with an enigma machine
the secondary is a non gated housing
there is a 44mm gate to by pass back pressure to the big turbo
Currently there is nothing hooked to the top and bottom port about about 1.2 bar springs in the gate, im sure the gate is opening right now, how much i dont know, but it seams to be damn perfect.
untill the big turbo makes good boost manifold pressure is only about 50 psi
Im going to go back to the track tomorrow to work on getting the truck to 60 foot better.
The only bad part is the dashdaq only has the capabilities to run two extra sensors
in most cases you dont need another high pressure boost sensor, most trucks only make 55 psi anyway which is fine for the factory map
so you could monitor low pressure boost and low pressure fuel pressure ect
Thanks everyone
Managed to run a 11.54@120.98 today in the heat, played with the trans tuning allot so i only got one decent pass in, trans seams ok, just need to get rid of the first gear shift and things should move along better
and for all of thoughs who text me, i cant text back my phone is FUUUKKKKKEEEDDDDDD
Powerstroked162
On Da Juice
Wa. State
Thanks everyone
Good job stepbro
Jeff@Spartan
Georgia
Awesome buddy! You definitely have a 10 second truck. You've worked hard on this thing and deserve the good passes.
Thanks buddy im sure its got more in it just going to take some time to get it right
Administrator
he walked out of fast and furious 6 and went straight to the circle track.. he has nawzzzzz !!!
