Just got my Gearhead tunes! Questions/suggestions on settings, etc.
Jmoore1225
Ya, thats very similar to the 2 i mentioned. I'll be purchasing both the cold side & down pipe when i get all the projects done w/ the dang boat.... To many irons in the fire right now.
3brorce
Pretty sure that Spartans cold side pipe is the same as RCD's. I mean RCD makes Spartans pipe
Ronin
Earth!
Ya, that's very similar to the 2 I mentioned. I'll be purchasing both the cold side & down pipe when i get all the projects done w/ the dang boat.... To many irons in the fire right now.
There's ALWAYS something else demanding/fighting for attention/money; wives/girlfriends, boats/motorcycles, guns, etc.!
Pretty sure that Spartan's cold side pipe is the same as RCD's. I mean RCD makes Spartans pipe
Donna @ Spartan told me once who made them, I just can't recall who it is right now. Not that it really matters too much; spend your money with who you're comfortable with; we have great sponsors here!
WoodBoy
Alabama
I did a quick 0-85 WOT run on the way home from work 2wd. It hooked pretty good. Max Boost- 44psi
Max EGT-1746
FRP-Dropped to 23,500 then picked back up to the 24,5 Range
Max EBP-86 (71 Actual)
Ronin
Earth!
Max EGT-1746
That's on Hot Street, correct?
WoodBoy
Alabama
Correct
The boost breifly hit 44, mainly stayed below 42
The high BP #s were at approximately 39.5-40psi
3brorce
Max EGT-1746
How do these numbers compare to your IDP tunes? Would be awesome if we could get an in cab view of these gearhead tunes
OUTLAW_6.4
IN
Thanks, its a good look and ride
SCT 3015 R is stuck on stock and will not load custom tune or sct tunes??
Error 1019 Unlock ECM Failed
Error 1017 Upload Stock Failed
Error 1009 No Tune Changes Written
Couple days ago I put on intake exhaust and street sct tune. Just got my custom tunes in email so I plugged the sct in to my computer. the auto update thing failed to work and said return truck to stock before i tried so i did that.
Truck is back to stock. Then i loaded the 3 custom tunes on the sct and everything looks fine. I tried put the custom tunes on the truck and i got the error code, then i tried to put the sct tune and same error code. Then i tried to put back to stock again and it said already back to stock.
The truck will start and has a code on the CTS about the dpf so i know its back to stock.
Can anyone help?
B585Ford
WV
Sorry guys. Just realized I looked at the wrong date.
