Start of my build
Skinny
British Columbia, Canada
Thought id share some pics of my compounds build not greatest pics but. With some help from JJ @ Dozers we used some of his parts from his reg return but thought we would try something different and feed the back of the heads and exit out the front please dont flame we are just trying this cleans up the engine alot! Doing a remote oil filter will be posting more on that as it goes. We had some old Fass systems at the shop that where old stock so to save a couple bucks. BIG BIG BIG THANKS to PDR Diesel here in BC for taking on the build:clapping:
Blacksmokin22
Who's rr are you using? Let us know how feeding the back of the heads works out!! I like the idea. Good luck on yur build, looks good so far!!
Pizza pig
In the Brig (Banned)
MD
feeding the rear and returning the front is no different than feeding the front and returning the rears. I feed the rear of the heads and return off the front on my truck.
Skinny
Made most of it at the shop. Got a kit from dozers decided to do something else use a little of his kit made the rest of it.
Sent from my iPone sitting on the crapper
motoxracer42
The front of the head is actually quite a bit higher than the back, since its a regulated return its irrelevant but for someone not flowing through it makes it a pain to prime.
Extended Power
I got mine flowing through the front of the heads first and out the back because I didn't want any added heat from the exhaust up pipes added to the fuel before it gets to the cylinders.
Since it passes out the back of the heads, and then to the return, I added a fuel cooler to mine as well.
Skinny
Should be Justin @ PDR diesel said he was using -12 ill be going back To the shop Monday and will have more info.
Skinny
Was like Christmas today for me!
Oil cooler cover for filter relocation
Fass fuel pump
PDR updated up pipes
New intercooler
vcassens
Godfrey,il
Yes I will probably run it on BDs dyno in the spring the truck will be lowerd and 32s want to switch it up.
Can't wait for that I want to see what mine will look like lowered. Where did you get that platform to stand on?
Sent from my PC36100 using Tapatalk 2
kyle43335
i feed from the rear and return from the front always. makes for a nice tight clean install
