Just wanted opinions on the best option for leveling an 01 SD? Everything I've read on here has been a bit expensive. Leaning towards just an add a leaf or a shackle kit. Any sugestions would be great. Website links would be awesome also. Thanks.
Shackle or leaf pack, i guess you could re-arch the springs as well.
Awesome. That's a lot cheaper than a $300.00 shackle kit...
If you're really on a budget you can find an old set of 450-550 springs & pull the lower 5 out. They are setup almost exactly like that pack.
Quick derail.-- will the leaf pack and shackle work together to make it a 3.5 lift
Have you measured to see what height you need?
Best ride quality will always be from using a V code factory spring. You can get a hanger lift in 2,3 and 4.5" which will enhance the ride quality by giving additional travel.
If you want new springs and 2" and the best ride quality get X code springs will ride better than any lift spring.
As always a 2" lift needs longer shocks and requires a adj track bar or a correctly made drop bracket to correct the axle that has now shifted 1/2-3/4" per 2" of lift. Its geometry.. a science. The axle shifting will side load your spring bushings which will cause premature failure and doglegging.
