powerstroked08
Ok im planning on doing a low budget build here in the coming months. My truck is a cclb zf-6 speed. I currently have a mini maxx with mcc, studs, ported and coated 6.0 manifolds, coated up pipes, flo-pro intake elbow and intercooler pipe, diamond eye 5" exhaust with 4" down pipe, and S&B intake. Now my plan is to do a ported intake (either rcd or dr diesel) wastegate, and the tow power plus turbos. Now the question is it a good benifit to buy both turbos or just do the 72? i dont mind doing both and im hoping by having the larger 59mm hp turbo with the larger turbine wheel it will keep the ebp in check without having to rely on my wastegate so much. Not to mention i would think that the billet wheels being on both turbos should help with spool up and possibly help with the egt's as well as the ebp. But thats just my opinion and my hope!
