***If you have Ported rails, please do not vote as we already know these cause the same problem****
Im going to start a thread so hopefully we can get a number of the people having problems and narrow it down to who has the problems.
The symptoms are usually at light throttle, right after it kicks in OD, if you monitor your FRP, it will surge 2-4k psi rapidly and cause a shake resulting in you having to let off the pedal or give more pedal.
I know Eric's newest tunes have a problem with it. The problem SHOULD only be with extreme street and/or extreme race. Extreme X should not do it.
I will also add polls for other brands.
After voting please give a discription of the tune and your mods.
*** Stock fuel = factory lpfp, factory hpfp
*** Aftermarket = airdog or airdog w/ elite upgrade
*** If you vote for (Other Tuner/Tunes) Please specify which
