head removal question ASAP
bluedge8
Champlin MN
what are you going to do for a rod bearing? if you put a new one in you have to make sure you get the right one, I think I'd try to use the old one, you are changing the rod also right?
89 Stroker
Southern Cali
this was at the bottom of the oil pan, anyone know what it is??
Parker, TX
Can't be positive, but it looks like the tappet from a fuel pump. They have been known to fall out and drop into the pan. Cheers!
89 Stroker
Southern Cali
idk how long its been on the bottom, but i take it it has a mechanical if it ran all this time
bluedge8
Champlin MN
do you have a fuel pump in the valley?
one of two things happen:
1. someone dropped it when they changed the fuel pump and bought another instead of fishing it out
2. or, you have been converted to electric fuel and have your fuel pump on the frame and it fell in at that time.
you didn't pull the fuel pump when you pulled the head did you?
89 Stroker
Southern Cali
there is a pump in the valley and no i did not
89 Stroker
Southern Cali
got the piston in, only issue i had was the first ring compressor failed on me so i had to buy another one
just so i know, what do you guys use to seal the oil pan on? ford silicone or whatever, or stuff from an auto store?
Powerstroke Cowboy
Montana
anyone know the torque specs for the rod bolts around the crank shaft>?
Take them to 76 FTLB for the first torque sequence then go to 96 FTLB for the last torque sequence.. This is for the bolt that hold the main bearing in place that go around the crank shaft.
Ford gray.. Do not use anything else other then the ford stuff for the 7.3L. Otherwise the oil will foam (or so it has been told and tested) which in turn will mess up the way the injectors fire.. They need pure oil not air filled oil. With air filled oil the HPOP cant even do it job..
Part number for the oil is TA-31
