5R110 swap - '08 to '06
06_Whitebull
Kansas
I'm pretty sure there isn't an issue, but I'm just double checking. I have a 5r110 from a 2008 F250 2WD gasser that I was going to have built for my '06 Diesel. Since all the internals will be new I should just be able to swap the tail from my 4WD tranny and be set, right?
kyle43335
In the Brig (Banned)
2wd and 4wd tails are basically the same
06_Whitebull
Kansas
kyle43335
That is the issue, I picked up the mentioned transmission for $100, has 75,000 miles on it, and was slipping in 2nd.
Getting a new PI converter.
I thought the tails on the 2WD were longer?
nope. all they do is put a companion flange on the end of the out put shaft when its for 2wd use.
did you ever notice the output housing is the same????
