jdgleason
*** my truck doesn't even clean 100% nozzles up. Still tons of fuel left over
With 2 72's lol
nice, will a dragon fire push enough fuel to 60%'ers? i guess there was some reliability issues but rcd said that was worked out, not wanting to run dual pumps.
They stopped making them because more often than not, they are piles of crap that destroy injectors when they go out.
interesting....
Just so I understand the logic here, even though this is completely off topic...
If you were mathematically injecting the exact same amount of fuel which should (in theory) make more power?? Big nozzles + less PW or Smaller nozzles and larger PW??
It depends on how much air you have and if you have twin injection pumps or not. If you run a big nozzle and don't have the air or enough pump you have to pull PW back or else it will have low RP and smoke like a freight train, it would be a dog too. If you don't have a lot of air or pump you can run a smaller nozzle with more PW too, but all of this is loosely stated as percentages of nozzle and pump or pumps as well as turbo sizing all depend on what PW you can safely and effectively run. If you have enough air and fuel to support a large nozzle you can crank the PW up to an extent of the abilities of your set up.
