6.0 manifold swap question
GROSSpolluter
So Cal
ive got mixed answers on ebp sensor. some say use a 6.0 tube some say use stock tube. anyone have pics? i want to get all my parts lined up and get it done the first time not be running around at the last min looking for parts. thanks.
BFT
southern cali
Stock 6.4
Edit: there is a bung in the driver side manifold where the tube and sensor will go to. Just tweak the tubing a bit and vuala
madman1234509
mayfield, ny
Ive heard of some having issues with their ebp in the 6.0 manifold, possibly contributed to more heat closer to the motor? I have a set of coated manis, my ebp will be in one of the up pipes
BFT
southern cali
I relocated my sensor right by the oil dipstick. Granted that the tube is directly on the manifold I personally never had a problem. I've changed out two sensors in my old CCSB and in my RC and both were in stock location.
Before my 6.0 manifolds I did have it in the up-pipe
04hdfatboy
I believe the dark horse diesel up pipes have a bung for the ebp sensor tube right?
JuststrokeIT
I ran a stock one upside down for awhile but I didnt like the clearance between the plug and the coolant tanks bottom hose so I switched to a 6.0 pipe faceing backwards havent have a problem with it yet i think its really personal preferance really if you feel like saving a few dollars and your stock ones clean just bend it a little like BFT said and call it good
GROSSpolluter
So Cal
the new up pipe has a bung in it. was going to cap the hole in the manifold and run the tube to the up pipe. but was wondering if the stock 6.4 one will reach or use one from a 6.0...or is the reason for running the 6.0 tube so you can put it in the manifold??
08BIGRIG
WI
I used the 6.4 ebp tube. It works great. That is what I would recomened
TX_S
this is how i ran mine and havent had any problems with it at all just bent a lil and used zip ties, theres prolly a much better way to do it though
04hdfatboy
Does anyone have a part number for the 6.0 exhaust manifold bolts and spacers?
16....shoot me a pm with your shipping info please. .they will go out in the am
Sent from my SPH-L710 using Tapatalk 2
had i known more when i bought the manifolds from you i would've got them from you as well:fustrate:
