Wheel/Tire Tech Thread
BlueOx
Ok got a question fellas.
Currently I'm running 37x13.50x20 Toyo MTs on a 20x9 wheel with a -12 offset. I have a 4in lift on the truck and had to trim the front bumper bracket and a little bit of the factory fender flare to clear them. I just bought a set of 20x10 rims with a -25 offset. Do y'all think I'll have any problems running the 37s on the 20x10s? Here's a pic of the truck I'm talking about just in case y'all were wondering.
And a quick pic of the new wheels I'm wanting to run
Sent from the wild blue yonder....
BlueOx
Bumping this up. I'll be picking them up today from the polisher and I'm gonna try and get them mounted tomorrow.
stroker2
Durango/Fort Collins, CO
Here is my 06 with a leveler and a 1 ton block with Dale Earnhardt signature series 18x9 with i believe a +18 offset. I was told they were a 0 offset when i bought them but i didnt think they stuck out enough to be a 0. If someone knows, please confirm this. I also have 35" Dick Cepek FCII's mounted on them
BlueOx
Well here's the Ox as she sits now.
2012 F250 CCSB, 4in Zone radius arm lift, 20x10 Centerline Scout polished rims with -25 offset, and 37x13.50x20 Toyo MTs. Front bumper bracket was removed and I did minor trimming to the factory fender flare to alleviate any rubbing. I can turn full lock both ways without any rubbing. It does however rub if I hit a bump hard while turning sharp or backing up at full lock but it's all rubbing on the inner plastic liner.
Crownsville, Maryland
17x9 fuel hostages 35x12.5. And 2" spacers in the last 3 pictures
Sent from on the commode with Tapatalk 2
slowcoupe
Las Vegas, NV
Glad to see this thread continued on. Have a question about offset and tire size. I'm wanting to run 22's on my 08. However after having other trucks with a wide stance and getting rock chips I'm wanting to stay somewhat tucked. The 22 that do not have -44 offsets are mostly 9.5" width with +12 offset. Will I be able to run this with a 37/13.5/22 toyo? I've looked for pictures of this size rim and did turn up much. Besides trucks with shorter all terrains and street tires.
STROKEDOUT
NC
New setup.
20X10's Maverick's -24 offset w/ 305/55 Toyo A/T. 2.5 inch lift front and rear. Does have slight inner fender rubbing at full lock.
Old setup was 20x9 Rock Stars w/ 35x12.5 Procomps A/T. 6 inch lift.
Sent from my ADR6400L
powerstrokin15
Charleston, WV
a buddy of mine is gonna try and throw 37/13.50s on a 07 with 20x12s and 6" of lift. I think he can make it work with some trimming. anyone else agree
Sent while charging my POS iPhone 5 battery
BlueOx
I bet it would work with some minor trimming! And I'm sure it'll look sick too
WydOpen
Boise, ID and GoM Offshore
Very minor rubbing with my '10. I don't know what the fender well clearance difference is between the 05-07 and 08-10.
My 2010 with 6" lift, 22x11's, and 37x13.50-22 Toyos...
AKHILF
Eagle River Alaska
It will be pretty close I'm pretty sure it will work. He most likely will just have to pull the inner fender back. -44 offest right?
