20x12 on stock height trucks
davidyack
Just pulled the trigger on some 20x12. -44 offset. Planning on 305/50/20 toyo all terrains. Truck is an 05 2wd with a 2"spacer In the front.
07_powerstroke
Upstate, NY
I would leave the suspension stock I had a 2in leveling spacer and it was way to much fender gap for a street tire. Just pull back your fender liners or trim them a bit if it rubs but mine doesn't run
Daryl@TDP
Chesapeake, VA
That 2" spacer might put that 2wd truck where yours say stock being a 4x4.
Josh@DirtyDiesels
PA
Leave it stock and see if it works. I think stock 2wd is about the same height in the front as my lowered 4x4 and I clear 12's with 305's fine
Frank_C
Orlando/Jupiter, FL
Just got my 20x12's with 305/50/20 420s on today. With 4400lb coils up front. Barely touches the fender liner at full lock, so I'm fine. No need to trim anything on mine
6
6.4stroke
Guest
If only pa wasn't so anal about wide tires I'd probably bump up to 20x12. They look mean
