Lets See Your 6.4 Under Hood Eye Candy
Beechperformance
DPC setup.
New setup.
Matt
Minnesota
Well I mean I know that much.. guess I asked the question wrong. Is it an upgraded pipe or something? Doesn't the stock pipe go under the vgt ?
On stock style turbos it goes down low. That isn't a factory atmo charger and the vgt has a larger compressor cover as well.
BFT
southern cali
:whs:
That pipe is specific for this turbo setup from elite diesel which are high power turbos (62mm VGT/ 76mm BB precision turbo.
The set up you are thinking of is probably the high power X (like what webb06 has) which is a bigger wheel and factory compressor housig on the VGT (59mm) and the precision BB 76 which has a cast wheel if I remember correctly
webb06
Seneca, MO
:whs:
Tow power x for me.
Richmond IL
what size is the atmo? looks nice
Thanks Wayne! and it is a 80 :)
Where's the build sheet on this beast at?!
There is no build sheet yet .... doing testing for as of right now. stock fuel and stock upper half . stock trans . :). I will know more after this weekend might get time to go to strip and see what we can do. :fordoval:
08BIGRIG
WI
Finally got it all done hay bud. Looks really nice. I am tuned in for results man.
bluedevilslax
Castle Rock, CO
I give single one you guys props for the work that you all have done to your trucks. All fo them are not only clean looking but every single one is innovative. I hope to be in the thread one day.
Richmond IL
Thanks jerry! Yep almost finished :) even no need to cut fender well either ;) can't tell a thing outside the truck:). I lost your # when I ran over my phone on a test drive . Shoot me a text or a call out something man :p.
Hope everyone likes it .
Administrator
your atmo is prolly a great choice for the combo! look forward to results!! good luck !!!
08BIGRIG
WI
Will do bud. I will talk with ya soon.:blitzed:
