farmin powerstroke
McLean county fair ground starts at 6pm.
Negative 4.88's. I'm running a 13.2 final. It may get bumped to a 14.6 final by Thursday.
Not bad, truck sounds nasty.
Since our last performance mods we been running a 12.80 FDR 4.56 direct drive and has never yet powered out. 285 tires.
http://www.youtube.com/watch?v=DU4ZBfT66UU
http://www.youtube.com/watch?v=70cZTBU3T2Q
This must have been after I saw you at TS? I also can't unlock my torque converter to help spin out. There's also a pretty big difference between 285's and 35/12.5's. I'm interested to see how it runs against you. Will you be at schieds?
And just wondering how your getting fourth gear out of a 5r and its not breaking. Most people run third with a 5r.
Isn't 4th in the 5r direct? So it would be just like 4th in the 6 speed and 4.56 would do good with only 285 since they aren't as wide but still about 33 tall. Sound like a good setup to me.
How many rpms are you running?
Difference between 285 and 315 is 107mm more tire on the track or basically 7in. And his are 33" and mine are 35". So I have more rollout. Basically I have a lot more tire on the track. Which is why I am hooking up hard. But it may be hurting my truck some.
I'm going to air up the duals a little bit. And take off harder. It's only made two hooks. There's a lot more potential in this truck.
Sorry I wasn't trying to say you have a bad setup, really your is better as long as you find the power to do it. I was just saying his has similar roll out and only has to buy cheaper 285 recaps haha.
We will be pulling tonight. Also heard that the black puller, the one Jeremy (lubeowner) is associated with, is planning on being there! I'm more excited to see that than beating a bunch of duramax's!
Take video of the whole class...
