Wheel/Tire Tech Thread
83f350
easton ma
I was wondering if on a 2000 f350 would 37x13.50's rub on a 6in lift? im running 20x10 rims with a -24 offset. any help is appreciated
BigBluediesel08
Laredo,Tx
What would be the perfect tire size for a 22x12? Would like 35s, but not sure if they make a 13.5 for a 22in wheel. Don't want/like the stretched tire look.
Pikesnogle
Ashburn, VA
Alright, my eyes hurt from looking and searching for an answer to my question.
I am trying to find out if I could run 305/60/18 Pro Comp Xtreme AT's on my STOCK height 2006 4x4. It looks like the stock rim will be ok as far as width but I am concerned about rubbing.
Any info would be appreciated.
Sorry if I re-posted.
-Alex
ltlbsteed
Hey all... great thread with tons of info! I've read this entire thread and haven't quite found an answer for my question: I'm taking delivery on a '13 cc 4x4 F250 w/ FX4 tomorrow and the first thing I need to do is get some wheels and tires... What I really want to do is put 22" rims on the truck with 2 1/2 inches or so sticking out the side - just not sure what rim width, offset, backspacing I would need and what tire size would fit - I really like to fill out the wells as much as possible and can handle minor trimming. I am planning on a 2.5" leveling kit too... Any input??
hagan525
Alright kmc xd riots with +18 offset wrapped in 37x12.50R20 on a 2011 f250 with a 5.5" rough country lift? I had 37x14.50R20 but the tires hit the radius arms so will the 12.50 fit?
Lift kit was supposed to be. 4.5" but they sent me 6" springs and a add-a-leaf
ltlbsteed
22x10's with a 35" tire should work with minor trimming on a truck with a 2.5" leveling kit.
Thanks Jeff, that's what I was hoping would work. What offset and backspace would I be looking for to get 2 1/2 or so out the side?
20007.3stroker
Cuba City, Wisconsin
Looking for a little advice on this exact topic!!! Right now Im running 285/75/16, well Ive been on a look out for 16.5 rims so I can run humvee tires(trying to save a few bucks on tires). Finally found some locally that have the super duty bolt pattern. The military tires are 37/12.5/16.5. Im trying to figure out what if anything I would need to do to fit them. Heres a pic of how my truck is sitting currently.
RollnCoal
Hello, I know it's an old post but I'm wondering how everything worked out with your 20x12" and 35x12.5x20" tires on your truck with the 2.5 leveling kit? I wanna go with the same set up but I'm getting mixed feedback on the possibility of it working or not. Some say its darn close, others say its not possible. I seen you bought the rims so I was wondering if it worked out good for you and if so, how much trimming if any was involved? Thank you!
