H&S Motorsports new fuel filter design?!
BlueOx
Just saw this on FB, any thoughts on this fellas? Looks pretty slick to me! And would probably save a bunch of money in the long run on filter cost.
Sent from the wild blue yonder....
Idiesel
The only thing is can you buy your filters separate? Bc everytime I've bought my fuel filters they come in a set
BlueOx
That's a good point! I've never really thought about that!
4EverBoosted1
Unless you are running dual fuelers I don't see the point. Ford sells the filters in a set, also there isn't really anything wrong with the factory setup, very easy to change. IMO
stevens6.7
Houston
Sorry for the newb question but how often do you change the fuel filters?
4EverBoosted1
I am excessive.. Lol my truck gets babied. I don't like running anything over 5k miles without new oil
Fuel Filter Conversion Kit
We originally designed the fuel filter upgrade just to be used in conjuction with our dual fuel kit, but figured we might as well offer it separately for those individuals who want to save a little bit of money on fuel filter changes while adding a little bling to the engine bay. Unfortunately after some digging, we found that the OEM fuel filters cannot be purchased separately (to our knowledge).
That being said, if you need to tap into the low pressure fuel system for whatever reason (fuel pressure gauge, custom fuel setup, etc.) then the fuel filter conversion kit is a clean, easy way to do so.
