My 6.0 build
Josh@DirtyDiesels
PA
ooops.... hate when that happens!
Josh@DirtyDiesels
PA
Decided to do a bit of under hood cleanup and wire looming while the truck is apart... also sent some stuff out for some color :)
Josh@DirtyDiesels
PA
Think my next major under the hood thing is going to be moving the batteries to the bed and where the heater box was I'm going to do a "box" that will have power terminals on/in it and will also be home to a nitrous solenoid or two :)
Stroker04
Gettysburg PA
Is there anyway to delete the fuel filter bowl without getting rid of the oil filter housing? I know its all one assembly but I didn't know if anyone knew a way. That would free up a lot of space and make it look nice!
05wh250
hendersonville, nc
I'm pretty sure you can get a oil filter housing off a 6.4 and do that.
smokinstroker
You can
A) cut your fuel bowl off the oil bowl.
B) buy a 6.4 oil bowl
C) buy an oil bowl relocate and move both filters frame side.(frees up a TON of room)
