New Product…..Rigid Dually Fog Light Mounting Kit
03-Blue-Powerstroke
PA
Here's my D2's. It was getting dark and kind of hard to take a picture but, they are so stinking bright :D. It took me about an hour as well. I got some help when it came to putting the bumper back on because it was hard to get the bolts started by myself.
South Florida
Who did the HID retrofit in this truck and what shroud was used?
It was done by Retro Shop. I believe they are Gatling shrouds.
Josh will these bracket work with the baja designs squadron?
The mounting is the same as the rigids but the lights seem to be a little bigger. I don't see a problem with these. I am a Baja Designs dealer if you need lights too.
Looks great! D2 are ridiculous bright.
Administrator
my D2 are bright as hell. brighter than my HID headlights. took me about 2 hours . great work josh and thank you.
6.7Stroker
Got mine today and installed them a little while ago. Wasn't hard... Only thing is there's no way to adjust them once they're in the housings so make sure they are where you want them!! If you want to do this without removing the bumper, it is very easy. Just remove the 2 bumper side brackets. Remove the one bolt on the bottom of the fog light plate, and just loosen the top 2 fog light plate bolts, the plate is slotted and will slide right out of the bolts. Quick, simple, and you don't need to remove the bumper. Love this kit and the lights.
Tom@BigTimeKustomz
Bayville, NJ
What HID's are those?
6.7Stroker
Couple more pics
