Is this the T4 .83 turbine housing everyone raves about?
Extended Power
Just curious, because it may have a T4 flange on it, but they sure don't have T4 port size...
Pizza pig
In the Brig (Banned)
MD
whats the rest of the housing look like? Definitely looks nothing like we've used.
Extended Power
Well, I'll give it a shot anyways...see what happens....if its a laggy POS, it will come right back off, and I'll just go back to my T3.
JDub
Hooper, Utah
That is not a genuine Borg Warner turbine housing. The Borg .83 a/r will line right up with a standard T4 gasket...
Extended Power
Oh really??
I posted these to show the Borg Warner symbol cast into the housing, and the part number.
JDub
Hooper, Utah
Guess i should've worded that post better... "doubt that is a genuine borg housing"
Doesn't look anything like the Borg .83 housings on our shelves...
Extended Power
Do you have better pictures than just the flange?
The exhaust outlet is a marmon flange, I had an adaptor made so I could use my HX40 connection on it.
MorganY
college station, tx
This is the only close-up of I have of mine. I do know the ports were very close to the T4 gasket.
Pizza pig
MD
this is a true BW .83 divided housing... same marmon flange.
They offer a few different ones, the small port housings are s200 housings machined to fit the s300
