Piston discussion
groove
Okanagan BC
Subscribed. Will be assembling my block with de-lipped 0.030 OEM slugs.
No cracks in 260,000km on the stockers, but ate a bunch of rings..
mike@haller's
Cheyenne, Wyoming
Here it's one I took apart today. Stock for 80k miles deleted for the last 20k. Cylinder wall is cracked in 3 places to.
weekendwarriorfsw32
Central California
Mine made it 140,000 before it cracked a piston. Spartan, KEM, Innovative, Gearhead 2008
Another truck I am working on right now made it 60,000 cracked a piston and now has 10k on International coated pistons and I believe it has a cracked piston again. KEM and H&S 2008
Another truck with 40,000 has to what I think is another cracked piston and this truck is a 2010 H&S tunes
Kind
Has anyone ever cracked a coated hd piston yet?
This is the best I could do. 6000 km's. But in reality it was caused by bad casting rather then stress.
Sent from my subconscious to your screen.
B585Ford
WV
Stock pistons. Put 30k miles on them with intake tune exhaust. Switch to a single 75 & 80 mm turbo for 15k miles. At least 15 passes on it as well as a DD. then I DD it with the quad setup for 5k miles, zero issues whatsoever
I think your pistons almost have to be a fluke. I have been following your builds from the beginning and I can't believe they are still holding. If you ever do replace them, if you can find a batch number, please post it. I would love to see if there are others from the same batch with similar results.
B585Ford
WV
There is a guy on the .org that just cracked one and cut a piston in half to find a factory flaw. I don't want to post a link to the thread though without a mods permission.
That was definitely an interesting finding.
Cknox121
Augusta GA
110k.bought the truck from my uncle, tuned since 24k with SCT. Now have 130k with h&s custom tunes. No problems related to pistons.
V-Ref
9 miles high @ 550 mph
So for someone looking at buying a 6.4 ... this thread...is it something to cause pause...or not? Seems like a lot of cracked pistons out there for tuner only trucks.
Is this a deal where it's a 7.3 pmr rods, 6.0 heads, 6.4 pistons...6.7 ?
Serious question. Say a 6.4...deleted, tuner only...otherwise stock...are cracked pistons a inevitable reality with the 6.4
Stroked777
Casper, Wyoming
Cracked pistons on these trucks are hit or miss. Some people crack them when stock and others can make 1300hp and daily drive the truck with no problems
