My memory is foggy, but didn't you have something similar?
what was the lash adjustment for? did you have solid lifters, or did it just remove some of the tolerance stack lash in the stock system?
I like that I am seeing more rocker arm options for the 7.3. I know there are several different people that have looked into it, and some are suppose to be getting things made, but I found it interesting that these are just simply a beefed up stocker design with a rounded tip, adjustable lash, and a ball bearing as the fulcrum point, just like the stock units.... that all seems awfully spendy for just a beefier rocker.... I was just curious what everyone else thought.
Yes - I had a set of adjustable billet roller rockers in 2006.
Those look like Wipe Out Enterprises.
www.wipeoutenterprises.com
6523 Dawson Road
Sidney, OH 45365
(937)497-9473
[email protected]
I had solid roller lifters.
Actually I converted the factory hydraulic roller lifters to solid to be more specific.
Could these roller rockers not be used with the existing hydraulic lifter? What would be the disadvantages of using hydraulic over solid?
Sent from my DROID RAZR HD using Tapatalk
Why would you want to spend all that money on rocker arms and not take advantage of the benefits?
Broken stock rocker arms generally mean piston to valve contact. I have never opened up a 7.3 from a pickup that didn't have some indication of piston to valve contact.
To answer your question: sure its possible - if you can figure out how to set the preload on the hydraulic lifters with the adjustment portion, you can use them. I wouldn't spend the money personally.
IMO I think they put a lot of R&D into a useless product. Not useless in the sense they won't perform as claimed, useless in the sense that there isn't a market for them. Anybody needing a better rocker option for a 7.3 would almost always go to a billet option before going with these. I agree 100%, they're just a beefed up stock rocker.
BTW, Carson is working on rockers right now, just another option to consider.
