7.3+75psi+400cc=broke rods?
blcsmok
Still trying to find a company to order my parts from. Requested quotes from a couple still haven't heard back. :cursing:Any recommendation for a company like to get all my parts from one place need someone that can fire ring also. if ur a distributor feel free to message! need to get this thing rollin again!!!!!! Thanx
V-Ref
9 miles high @ 550 mph
Unlimited Diesel has worked real hard to make sure my power goals are met. Great communicator. Johnny on the spot with coordination/follow up. Knows the platform and industry in and out. Nate gets my vote for you.
97stoker350
south central pa
I would go with swamps personally. If I hate money I'd be sending a motor to them to have built. I've got sstuff and dealt with them dice my build started. Dave has been very helpful
m j
BC Canada Eh!
how hard is it to find a machine shop to fire ring it?
I have started hunting locally for a machinist and the first place wouldnt even replace the injector cups
Powerstroke Racer
Brenham TX
Find a competent CNC shop and buy the tools to do cups yourself.
2nd option is to buy a BHJ cutter and cut the grooves yourself.
$1500ish for the tool if this is correct p# ORG-3-SK-DR120 plus a grand+ for the register plate. pricey for one or two motors
I am in for a good local CNC machinist contact info, share plz :)
I will definitely get the injector tools
Its a wash. A good shop will charge you as much for the work.
