6.0 Build This Week
Shield13
05 Harley Davidson CCLB 90K,Its time it just started sippin coolant. I am using Southern Diesel in upstate ny,
egr delete
oil cooler
head studs
blue spring
ficm
sct tuner
5" exhaust
RedRice589
Ocala, Florida
egr delete
oil cooler
head studs
blue spring
ficm
sct tuner
5" exhaust
Southern diesel- upstate New York...... Hahahaha
Is the guy from down here?
Also that's not a build that's just making it useable!! :hammer:
Shield13
FORD
It says FORD on the Title, which means that its better than just useable, Ive driven it 90K miles and havent put a nickle in it, ask the other brands if they can do that, driven hard daily.
powerstrokedkid87
New Jersey
I would make sure they pull the HPOP cover and check the STC fitting as well. If its not updated make sure they do update it. Also I would add dummy plugs to that list, as well as new injector orings and copper washers. 6.4 banjo bolts, coolant filter.
Few other performance items I may consider as well if your thinking of doing more mods down the road-
Regulated fuel return
upgraded up pipes
possibly a fuel system.
Twan
Berthoud, Co
To answer yes. 200,000k on my Chevy still strong, pulled trailers 70% of that. Unless you count Oil and filters. Lol.
Good luck on the build, will be fun! look into the intake manifold while it's apart too.
Powerstroke214
Baton Rouge, LA
Something I'd consider is a FICM tuner. And I'm assuming you have a monitor and coolant filter already? If not, I'd add those.
Can't wait to be done with that step…so I can start planning/saving for a turbo and injectors(just to make Mink happy LOL)
jdc753
Norton, MA
^^ This at least, not much more money or time at all compared to the rest. Might as well get it all done while you are in there.
Shield13
thanks
Thanks for the advice, I have had almost all of the things you guys mentioned, looked at.
