Help with park brake cable removal
CentralCali559
Farmersville, CA
Hey guys. I have a 2004 f250 crew cab 6.0 and I'm gonna be stripping the frame because of rust from CO winters. I have the passenger side done but the drivers side has the park brake cable in the way and I don't want to weaken it if the wire brush on my sander touches it. Any help on how to remove it or maybe loosen it so it's out of the way, would be greatly appreciated.
6.4psd916
Roseville , CA
If its the same as earlier years, you can disconnect it from the pedal in the cab. It takes a little work but its doable. Had to change it many times on the 2000 7.3.
CentralCali559
Farmersville, CA
Ok I'll see if I can disconnect it from the inside. We've been having some rain finally here in CA and that has slowed my progress. Thanks for the input sir!
webb06
Seneca, MO
You can disconnect it underneath as well. Probably much easier as well. Look for this right under the drivers feet under the truck ImageUploadedByTapatalk1393626482.598287.jpg
Sometimes the little nub sticking up needs ground off to remove the cable just depends how stuck it is. Wd40 helps a lot too.
CentralCali559
Farmersville, CA
You can disconnect it underneath as well. Probably much easier as well. Look for this right under the drivers feet under the truck View attachment 26363
I noticed that but I don't know if there will be enough slack to remove it. It's kind of tight already with the brake disengaged. I'll hit it up with WD-40 and see if my cousin can help me. Thanks sir!
webb06
Seneca, MO
Pull down on the cable and use vice grips next to the body mount to keep slack in it. I do it all the time raising cabs
6.4psd916
Roseville , CA
Oh nice, yeah I'm in the Visalia area, 45 mins south of Fresno.
That's where I was born. Have family in Hanford.
I do remember when replacing the cables that there was a joint there. But I was replacing the cables so it was already broken so I didn't even think of pulling that apart first.
CentralCali559
Farmersville, CA
Oh nice!! Yeah I was born here and live in Farmersville.
Yeah I'm just trying to move the cable away from the frame so I can strip it with the wire brush and hit it with paint.
powerstrokedkid87
New Jersey
as mentioned pair of vise grips against the body mount to hold the slack, some PB blaster to losen the connector between the cables, and I use a flat head to pry it open enough to slide the cable out
CentralCali559
Farmersville, CA
Ok my buddy that works at a tire shop came over to torque my wheels and he showed me that there's a quick disconnect past the rear drivers door, right before the rear wheel. You pull forward and unhook the hooks and the cable is loose. Thanks to everyone for the posts!
