CCV Mod
HOOV3R
Central PA
Simplified it? All I can see is that you did something without researching to do it correctly.
sootboy
In the Brig (Banned)
Maryland
Where do you work?
I am self employed. I own several business (a few of which are automotve,Diesel and Transmission repair shops) and multiple properties and investments. I would prefer not to disclose the exact details of these businesses or the locations or the nature of the business at this time.
I sincerely hope this does not offend any members here.
I am here because I own a 6.7 2wd powerstroke truck. I enjoy modifying and racing it. I only offer information on modifications I have actually tried on my own truck. I do not offer to sell them or offer an opinion on other items being sold. I have asked questions about traction and staging the truck despite the ridicule of others.
I have never drag raced a diesel truck before I bought my 6.7 a while back and it has been really fun.
If I am here for the wrong reasons please let me know.
If this is the reason the site exists I would appreciate it if you just left it alone please. Having you and your crew follow me around with hateful commentary is flattering but ultimately a waste of your time.
On this site I just want to be another guy with a powerstroke trying to go fast.
Thank You for your consideration Mike, Steve, kaleb, Morgan, Dustin, josh and crew.
Administrator
You sir are a liar. A compulsive one , with an addiction to narcotics. I feel sorry for you. I pray nobody calls your sweet shop for anything. You are now being banned. Stay gone.
HOOV3R
Central PA
The research has been done, and flush has nowhere to create an area of low pressure.
On the other hand, the newer design with notched tubes is supposed to work very well.
Looks like it would pull a lot of vacuum that way... how much vacuum is to much?
jordan572
What he said, I really don't feel safe running a dump into the exhaust. You might get a consistent vacuum at idle but how about when your pulling a trailer under heavy load. Only thing I can think of is welding the dump pipe/bung in where you think best and drive around with a manometer hooked to it, which could become a little over the top. I wonder how much Vacuum is to much like asked previously. I would imagine that you could have a decent amount as the compressor inlet where the PCV currently dumps stock I would imagine sees a lot of vacuum when in high boost.
I was thinking of finding the largest catch can out with the biggest fittings available. Mishimoto makes a can with -10 fitting or about equal to 5/8 hose, although this operates on a closed system meaning that the cleaned oil free air is meant to dump back into the air intake system. As far as I understand the process you could either return the cleaned air after the catch can filter back to the oe PCV dump spot or just let it discharge out of the outlet side of the catch can. Mishimoto claims that the can is a vacuum oriented catch can, meaning you need to run the outlet to a vacuum source. I don't see why you couldn;t just dump the outlet side of the can into the air though. From the looks from videos it looks like the 6.7 pumps a lot of blowby, don't see the need to tie it back into the system as I don't think it needs vacuum to assist the ccv process.
I would just plum in a vacuum gauge and see how much it pulls.. the bbc guys I worked with said that there is such a thing as to much but as long as its pulling vacuum even down to 1lb and not building pressure at any time in the rpm band then its good to go..
Administrator
theres just too many pulling into the exhaust without issue not to ignore.
dieseljosh07
Georgia
We've never once had a issue routing into the exhaust. Like other have said before it's nothing new, CCV scavengers have been around for decades in the gas engine industry.
Cratos
ocala fl, area
ccv
I’m not sure how you guys got the 90 and hose down past the fuel lines, in less you bent the heck out of them ,I ended up running mine forward then down past the brake booster. I could not see any other way without major fuel line bending.??
Cratos
ocala fl, area
I built my can with 1inch in and out and 3 layers of scotch bright and steel wool inside, then I ran it out to the pass side rear bumper.
