6.4 RCLB DD/Tow Rig Build
Taylor D
Sebring, Florida
Well guys just started saturday on the truck. This is my 1st ever cab off project and also 1st 6.4. Started around 8am sat morning and by 1230 we had the cab off including all coolers, intercooler, and radiator (was leaking) replacing with Mishimoto Radiator. Spent a couple hours on it again sunday and got the oil filter housing and fuel filter housings off and the turbos and accessory drive and wiring out of the way plan to pull the heads tomorrow or thursday.
Build List
H&S Wastegate Kit
Mishimoto Radiator
Banks Intercooler
OEM Lifters
Rudy's Valve Springs
RCD Pushrods
OEM Rocker Arm Asm's
MDP Billet Oil Filter/Cooler relocation plate with Fluidyne Oil Cooler
MDP HD Up Pipes
ATI Damper
Marty's Diesel A-1000 Complete Fuel system with Fuel Bowl Delete and Regulator
Extreme Headstuds from bigrpowr
New Fan Clutch
OEM Water Pump
RCD Intake Manifold
Elite 72 or 74 mm lp turbo deciding whichone gonna order this week
New idler pulleys and both tensioner asm's
New belts
Evans Waterless Coolant
NO Limit CAI
NO Limit Cold Side Pipe
4" DP to 5" dp back exhaust
Odyssey Batteries
PMF Dual Bilstein Steering Stabilizer Kit
and the list just keeps growing lol
Pictures to follow
Taylor D
Sebring, Florida
Sent from my LG-LS980 using Tapatalk
Yep that will be next gonna try to make it last for awhile truck only has 85,000 miles on it so should be good for awhile.
i dont wanna burst your bubble...LOL
darn solid build list looks great-while you are in there i would suggest aftermarket or 6.0 manifolds w/custom uppipes.
what tuner/tunes are you planning?
MINK
London,OH
LOL right
Taylor D
Sebring, Florida
Yeah i know the trans is the leak link now I'll try not to run it to hard lol. It's my dd so mostly hwy miles on open road no stop and go for the most part and no passes down the track yet but definitely after tranny is built.
Have a Dash Daq with Spartan tunes now but will have sct with gearhead tunes before build is done and use dd for gauges.
Have MPD Uppipes for 6.4 manifolds but think i might sell and go the 6.0 mani route
Taylor D
Sebring, Florida
Also still on the fence to go ahead and spend the money for a mild cam and nozzles what's u guy's thoughts on these and what kind of gain can i expect from them. Will the nozzles help much on stock hpfp and Marty's lp kit
Taylor D
Sebring, Florida
Also about to pull the trigger on the Elite 76mm is that the best choice being that I'll be on stock hpfp for a good while
B585Ford
WV
Looks like I will have my truck back by this weekend. Marty's, 15% nozzles, stock HPFP, and a 76. Send me a reminder and I will let ya know.
Oil Field Trash
Jonesville MI.
Looks like a great start to a fun build. I'm jealous for sure, my reg cab project is sitting behind my garage.
Sent while I probably should be doing something productive.
