Thinking bout a stage 1 cam.
swinky
Eastern, Nc
Nope..
I sell 6.0 Pushrods for 6.0 trucks
I sell 6.4 Pushrods for 6.4 trucks
Cool man, Me and Dorian are doing everything again so we'll be going through you for everything.
Do you see any problem with doing a cam, lifters, springs and push rods to a high mileage engine? I feel like I rarely see any lower end or piston issues with 6.0s around 600hp. Even if it did spin a rod bearing or something it's not like I couldn't re use the cam and all that stuff.
Sent from my HTC One using Tapatalk
ford rules
In my opinion if your gonna do it do it all. Cam, lifters, pushrods, rockers, and springs. At that point the whole valve train will be new and you shouldnt have anything to worry about. Thats just my thinking.
Most high mileage 6.0's that I see in our shop loose a lifter or have a rocker arm failure at that amount of miles, granted those are clapped out work trucks.
ford rules
You may also wanna take into consideration PTV clearance. Jared at RCD advised me to do reliefs if i went with a cam since i had to have the heads milled to.
swinky
Eastern, Nc
I'ts never ending. I'm sick of this schit.
Breaking Habits
Mapleton, Illinois
Its better safe than sorry.. first time you pull your fresh motor apart with bent valves because your machinist didnt properly recess the valves you'll be sorry you didnt.
.060 is safe enough. no worries, be happy!
swinky
Eastern, Nc
I was thinking cuts in the pistons lol I'm a little slow sometimes.
borsky
Barrhead AB, CA
I hope to have mine running with the stg 1 cam by the end of the weekend, ill et you know how I like it. But like others there will be many other mods done at the same time...
TooMuch03
West Bend, WI
.060 valve reliefs for a stage 1 cam? So we're giving up almost a full point of compression just in case the machinist doesn't know how to do their job correctly?
