2007 6.0 Egr valve question
hopefulHP
Mead Co/ Williston ND
At work we've got a 2007 6.0 and the egr valve is bad or at least that's the code it's throwing. Will the truck run still if I just take the egr system off and use blocker plates or will I need a tuner, also how long of a job is it to accomplish putting in just a new egr valve vs. Egr delete
Sent from my HTC6500LVW using Tapatalk
mcdaniel1991
Germany
New egr valve only takes 10 min to install. If not deleting the cooler to then the egr plate is just as easy but I would just leave the old plug in instead of buying a blocker plate. And yes it would still run but you will have check engine lights without a tune.
Sent from my GT-I9305 using Tapatalk
Atsah
Maine
For the price of a new valve and having the square cooler in the 07, I would delete that POS quick..
Lassie
Tenn River Alabama
And plan on six to eight hours for a delete with new oil cooler, possible turbo rebuild/cleaning. Even if it takes you 20 hours...worth every second on a 6.0.
