7.3 CCV Catch Can
Justin@DP-Tuner
Who makes that? Do well does it work to keep oil vapors from going back into the intake or does it vent into atmosphere?
Billy T.
[email protected]
As stated, it is just a strainer from Tractor Supply.
I route it back to intake, but you could do atmosphere as well.
It does a pretty good job keeping the intake clean. A little oil still gets in there, but not near as much.
got a P/N? do you mount it on the passanger side over the trans back into the intake.
Driver's side, and then back into the intake.
What's the inlet and outlet size on this?
1"... But I stepped mine down to 3/4" fittings because that is the size of the stock CCV.
Does oil still get into the intake and grease everything up?
A little, but not near as bad as a stock configuration.
How much oil are you getting in there?
This was after a couple thousand miles. Just a slight film on the screen and the bottom of the can. This will change depending on how much blow-by you have as well.
Stroked777
Casper, Wyoming
Sorry to derail a little but this looks like an awesome set up, surprised I haven't seen it in the 6.4 section yet
