I need some AC help...
CSIPSD
Bend, OR
Just thought I would post this crappy picture of 34* ac temp today...
bazdog1
34 degrees is not what you want to see. With 134a, your low side pressure is a 1 to 1 ratio for psi to temp. If your seeing 34 degrees supply air temperature, you are freezing your coil.
Either you are going to freeze your coil or your low pressure safety switch is going to cycle your compressor.
I think you've got a slight restriction in your system.
If you're happy, thats what matters, but I don't think its running correctly.
disclaimer: I'm an hvac mechanic that doesn't work on automotive equipment but do work on 134a systems quite a bit.
JLDickmon
or his pocket thermometer is not calibrated..
Bluke
Colorado
I believe you need to have the egr valve plugged into the harness to have the fan work correctly. Just plug it in and let it hang out.
