So it begins
Magnum PD
VA
Was told 300/200's is as big you can go and still be DD friendly. I don't know what to expect if have 600hp or even how to handle it.
golfer
Dave Armstrong has 400/400 in his family excursion. It's all in tuning
whoa...
I tried and tried to get 400s to be clean on the street...but wasn't ever happy enough to leave them in there...just hazy hazy...
200% nozzles are a breeze for a DD.
golfer
Hi Dave! I love those 200's y'all threw on for me. Hope all is well with you and the crew down there.
good deal, Dom!
yeah...we typically recommend 30s or 200's...see no reason for anything in between.
isootmypants
North Jersey
whoa...
Did I jump to conclusions?? My bad. Just referencing to what you said to me when I was going from 250/100 to my 300/200 from you. Mentioned you had 4/4 in the excursion.
njjeep
Brick, NJ
So are you just swapping out the rods and adding a girdle? Or are you doing new pistons too? Also, do you have to get the rotating assembly balanced?
isootmypants
North Jersey
Can't just "add" a girdle. Needs to be line bored and rotating assembly needs to be balanced. Fill will be added. So complete tear down is happening. All clearances and tolerances done. Pistons are already done. Just not coated
02BigD
Coastal NC
good deal, Dom!
Things have some a long way for the old dinosaur. There is no comparison between the 100 & 200 nozzle after having both for some miles now. Cooler, less smoke, which really blew me away with the 200's.
It's almost a shame to bury something so sexy inside one engine...
isootmypants
North Jersey
That is sexy haha. Mine are just delipped and radiused. 15.5:1. Coating just added security for heat and crack preventative correct?
isootmypants
North Jersey
Well doesn't look like I'm going to RRE. BUT everything will be done to the max. Having Carson build my motor again. Stage 2 cam, relief cuts in pistons, coated pistons, Carson is porting heads more. Twin terminator pumps and changing injectors to 450/400. Fire ringed heads and he will hot retorque for me on the stand. Ati dampener, precision flex plate, girdle and aluminum valve covers came in. Dropping everything off probably next weekend.
Obsledpuller
Gibbsboro
TJ I was wondering why you're going with the ATI balancer? I have a fluidampr and I'm not saying one is better than the other just curious as to your input on the choice?
isootmypants
North Jersey
Ati can be balanced with rotating assembly. Fluid dampeners, I've heard of gelling up on one side and throwing off balance
