2015 test mule
Buck1
Winchester, IN
Any had a chance to investigate or know if the injection pump is the same size? I thought I saw earlier somewhere that it was insinuated that it might be different than 11-14.
Buck1
Winchester, IN
Retrofitable? I am game to try. Mine won't hold on some big tunes, has 176k and I need an excuse. I'm happy to gpig if it is thought to be an improvement.
Not ready to commit to dual fuelers yet, or let's say momma isn't ready.
Powerstroked162
On Da Juice
Wa. State
As far as I have been told, it's a direct swap. I won't know for sure for a couple weeks though. I've got an engine here on a stand waiting for the pump
Btw, I have your rails done. You still have my number?
Buck1
Winchester, IN
I Beleive I still have your info. Will check. Thanks! I may give Ford a call then.
Athens, IL
Oh, and towed this too. Did just fine plenty power while towing. Didn't get hot but didn't pull it that hard.
The truck has 1500 miles or so on it and has yet to get over 11-12 mpg.
Might be the way I use it. I understand while towing, but empty it should be better. It does run harder than the older version. The spool up I've gotten used to.
More to come.
WHY NOT
Carlyle IL
Just about any time I hook a trailer behind mine my milage drops quite a bit. 13/14 at most empty with a trailer then I can have 26K behind the truck and still get 11
Athens, IL
Towing the pull truck I was at 8-9 range the whole way, in the Midwest where there is no hills mind you.
Order a pump from Ford, so the wait is on.
You got one too? I got one and a turbo.
WHY NOT
Carlyle IL
I know there aren't many hills I'm not so far away from you.
Sent from my I fone 5
Athens, IL
