2006 6.0 AC fuse issue
Blknite23
Hey guys/gals...
Ac quit working today.. blew the ac fuse (10 amp) under the hood.. i has a issue with this last year and replaced the entire system before the dealer found out it was a wire rubbing and grounded itself out.. problem solved..
NOW
i blew the fuse today... i put a new fuse in, ac blew cold for about 3 seconds then pop goes the fuse... does anyone know where the wires have the rubbing issue?
only answers i can find are about sensors and levels of freon.. everything works great but i have another wire rubbing issue..
anyone ??? thanks
-Tom
Gary
South Lyon Mi
If it blows the fuse that quick I would unplug the compressor and see if it blows the fuse, that will tell you if it's the harness or the coil in the clutch. If it's the harness it could be anywhere and you may have to open up the harness and follow the wires.
