2012 Excursion Conversion
Building a 2012 Excursion out of a 2005 Ex and a 2012 F250
Truck up on the frame rack so we can straighten the quarter. Gutted the interior and have all the wiring pulled out, striped and labeled for the conversion.
co04cobra
WV
I would love to turn more custom builds like this out of my shop. Looking forward to seeing the progress.
Started on the Excursion today. Drilled out the floor and outer rockers, Need to cut the inner rockers and the windshield pillars and the front part body will be lose. Pulled the rear drive shaft so all we have to do is cut the frame and roll the body, frame and motor and tranny of the frame rack. The 2nd row seats from the Expedition EL showed up today.
Got the rest of the body off today and the tank drained, gas, brake lines, electrical wires removed. Also have the rear axles all unbolted and ready to roll of the rack.
Got the frame cut on The EX today. Rolled the front half off with the motor and trans still in the frame. Rolled the back axle off and outside to. Put the 2012 on the frame rack and gutted the interior. Monday call for the windshield to be cut out and started taking everything off the underside off the truck.
Pulled the running boards, bumper, spare tire, hitch and everything underneath. Drilled the floor and rockers out. Hope to have everything cut a part tomorrow.
Sent EX frame, gas tank Sheild and hitch out to be sandblasted today. Got it all back today to. Great turn around time. Got the 12 all cut a part. Just got to roll the back half off the frame rack.
Welds all cleaned up and painted. Slide the axle out from under the box and put it under the Ex frame. Decided to use the springs from the truck so we have to move the front spring perches forward 8". Going to have the drive shaft shorten from the 12.
Got all the exhaust reconfigured and hung. All the wiring figured out. Last to do is plumb the fuel lines and drill one hole for the new shocks.
Got the shocks installed, broke out the bottom of the tank for the sending unit out of the 12. Need to lengthen the sending unit hoses and rods. So the gauge reads right. Also started lengthening the fuel lines.
Fuel sending unit lengthened and installed, fuel lines all ran and hocked up, took the hitch back off and sanded and painted it with industrial paint. Fuel tank has to come back down to put the hitch back on because you can't get your hands in the frame to position the nuts/keepers for the hitch bolts and you defiantly can't do it when the body's on. Monday straighten up the wires and fuel lines, take the tank back down put up the hitch, reinstall the tank and transfer the fuel from the 12 into the Ex, fire her up and driver off the frame rack and set the body on the frame.
