2012 Excursion Conversion
Wayne
Twin Falls, Idaho
It always amazes me how much time all that piddly crap takes, but without it the vehicle just isn't nearly as nice. I bet you're dying to install the interior panels.
Rear usb's installed, LED revers lights installed, started on the Firestone rear air bags and compressor, got the compressor, valves and all wired, installed some panels and uninstalled panels.
Rear usb by rear lift gate
Passenger side third row usb
Drivers side usb
LED revers lights
2000wa250
Damn that's clean. Props man. Looks like a lot of sweat (and maybe blood) has been put into this build. Well done sir.
Wayne
Twin Falls, Idaho
Uh, it looks like you forgot the headliner before the top trim panels went in :lookaround: Just messin'. LOL I know you are aware
Ran air lines for rear airbags, put back gate and doors together, put running boards on, remove DPF tank and exhaust, tunned with H & S Mini Max
Air Out
Deleted the EGR, got the carpet in, headliner back from being recovered and fabed up the rear heater controls on the 12 over head console.
Egr before
No egr after
Over head console
Sound detonation carpet backing
Front and rear seats installed, Headrest DVD's installed and wired, usb plugs installed and wired, heated seats all wired and working.
Not light on the base. Four coats of base and can still see the black coming through. Should of used a white or gray first before the base. Lesson learned.
