2014 Platinum F-250 Level From Factory?
yfz4kyle
So Cal
What up! I picked up a 2014 short bed F250 platinum a couple weekends ago. I measured front and rear and this thing is dead nuts level. I like to have my super duties sit about 1" higher in the front. So, I've always done 2.5" coil spacers on my previous Powerstrokes that were XLT and Lariat models. I did some research and read somewhere that the Platinum 250 short bed comes stock leveled? Does that sound right? What can I do to get that nose 1" higher? It does not have any sort of spacer under or on top of the front coil and looks 100% factory untouched.
jimdawg185
My 08 was level from the factory, not sure how or why. But my 17 definitely was not level. Both 250 ccsb
Brian22
Forney, Tx
My 16 sat pretty dead level.
Go with a 1" or 1.5" coil spacer for the front if you're after a nose high stance.
Why would you want the front higher? To blind oncoming driver's? Or just to look like you have something heavy in the bed...
Jomax
Arizona
Cali lean bro.
Most 250s are level. Mine is.
04cr450
harford county, maryland
Depends on the package it comes with. My 250 came with 350 blocks so it sat nose down substantially. Now I have the 2.5" icon lift and it's still 1/2" roughly nose down.
yfz4kyle
So Cal
Wow! Good to know! I'm thinking I might go with a 1" coil spacer if I can find one otherwise I'll do 1.5"
Swampfox
TN
Depending on how much you want to spend, one up offroad makes an adjustable coil leveler and you can dial it in however you want up to 2.5".
yfz4kyle
So Cal
I may consider that then! That sounds like I did on my F-150 with the Icon Coil Overs
