Watch "Thomas McDonald" on YouTubeIt won't let me post it to here for some reason ill try again
Sent from my SM-G892A using Tapatalk
https://www.youtube.com/user/murraymc711
Probably in KPa which is right in line with normal atmosphericBaro @ 101 isnt right is it?
Well I've checked everything I can think of and more and I can't figure it outProbably in KPa which is right in line with normal atmospheric
I just replaced them both when I did the the ****** along with a oil changeHow long has it been since you changed your fuel filters? My truck makes a similar noise under hard acceleration, although not as loud, but shows no codes on my ez lynk. However it shows a soft code on forscan as a high fuel pressure code. Don't know if it's connected with the noise but it made me think of it when I watched your video. What are you scanning codes with?
Sent from my iPhone using Tapatalk Pro
I'm scanning with the live wire and it was saying 1dtc but wouldn't read it so I took it to Napa and it was a p1247 code but sense I unplugged the egr plug I forgot it hasn't showed back u. I just put everything back to stock and completely factory reset my sct and ******d the custom tunes and did a firmware upgrade to the tuner disconnected the battery terminals for 30min and reloaded everything so I'm hoping this fixes itHow long has it been since you changed your fuel filters? My truck makes a similar noise under hard acceleration, although not as loud, but shows no codes on my ez lynk. However it shows a soft code on forscan as a high fuel pressure code. Don't know if it's connected with the noise but it made me think of it when I watched your video. What are you scanning codes with?
It is driving me absolutely out of my mind I can't stand having something wrong with my truck and not be able to figure it outSounds like work! I feel your pain, man. Stuff like this is frustrating to get to the bottom of. Did you put the factory tune back on then?
