450 keeps showing a wrench on the info panel
Corb@CorbinShipping
Autryville, NC
I used the spartan DD to clear the codes, and it goes away, but comes right back on...
4 DTCs
P0405-EGR SENSOR A CIRCUIT LOW
P0488-EGR THROTTLE CONTROL CIRCUIT A RANGE/PERFORMANCE
P1000-OBD SYSTEMS READINESS TEST NOT COMPLETE
P1335-EGR POSITION SENSOR MINIMUM/MAXIMUM STOP PERFORMANCE
EGR has been deleted...
I clear them, and they come back on in 5 seconds... had 275 EL loaded, Loaded a lower tune to make sure that Tony's trans didnt get trashed, so I loaded up the 210, then wrench lights started showing, I loaded different tune, then another, then returned to stock then back to 250 EL.... Same results...
Truck still drives fine, at the new power levels, No issues...
Any Ideas?
Corb@CorbinShipping
Autryville, NC
275 loaded back up, now wont start... Charger is hooked up... we shall see
I talked to Jeff. There is a 210 TP tune, but must be downloaded... Ill do that tomorrow. But gotta get the truck fired up...
Dzchey21
wyoming
Check codes again and make sure there are no e exhaust sensors throwing codes
Heavyhaul
Wyoming
Sounds like your on the right track. Good luck bud. You need it right now.
Rivets are the new duct tape.
Big Angry Hillbilly
You need different tunes for the EGR being totally removed don't you?
Even though disabled the PCM will still look for the hardware.
Motostroker
I had the same issue. Only the higher tunes will work. Try 275 and up. Only the newest update had egr removed 210 tunes.
Corb@CorbinShipping
Autryville, NC
All is well. Starts fine, 275 tune loaded up. No codes, no wrenches. Ill just drive like a puss till Aaron gets my trans and TC ready for install.
Thanks for all the help Dustin.
08BIGRIG
WI
What a pain in the a$$ hay Corb? Freaks you right out until it is fixed and running good. Glad to hear that you got it back up and rolling.
WoodBoy
Alabama
Just go to Spartana website anddownload the egr delete tunes. All are then full delete friendly.
