Binder man
- Joined
- Jan 6, 2013
- Messages
- 681
- Reaction score
- 0
I'd take a nv4500 over a 5600. You ever had to change an input shaft on a 5600?
Any chance the zf6 will bolt to the 5R110 adapter plate?
2003.25+ If it was behind a 6.0L/6.4L it has the same bellhousing as a 5R110. If it is earlier than that it would mate to a 7.3L, not a later engine.
Not true, I had to change my rear cover on my motor from zf6 to 5r110 to mate it up
Are we talking about an OEM plate or Destroked plate? The OEM pattern will be the same, but the thickness is different. A Destroked plate should be the same for both, you just add a crank spacer for the ZF. I think.
