6.0 Compound Setup
FaSSt9602
Gilbert, AZ
So how did this setup turn out? I saw the pictures on facebook and the idea of not intercooling the HP is really interesting. Very clean look for sure, but what are the IAT's like?
powerstrokedkid87
New Jersey
I know craig was till working on the set up, im hoping to have it in the next couple weeks and get it on my truck! should be a quality set up for sure!
powerstrokedkid87
New Jersey
HobbyStock62
Mpls, MN
looks great. what are all the supporting mods that have been done? i know fuel system, studs, egr, yada yada. but hpop, bottom end, whats done to heads, intake manifold?
Josh@DirtyDiesels
PA
Mark's truck rips. Drove it for a little the other night, spooled real quick and I lifted when it started to spin the 38's....
powerstrokedkid87
New Jersey
this truck has 265/125s from MPD, RR, Air Dog II, sun coast trans, Steed manifolds, craigs up pipes, and the compounds. Bottom end is all stock. for the little I actually drive the red truck, bottom end should be fine. Were still tweaking a few things, and have some items still need to be worked out (air filter ect,) over all this truck rips, spools so much faster than the sing 66 I had on it (66/71 .70 t3) and when it spools, its gone. Spinning the 38's is a joke. Have not even loaded the hot tune in it yet. Want to hook up the meth again first.
Josh@DirtyDiesels
PA
And you need to take that insanely retarded BOV off like right now
powerstrokedkid87
New Jersey
That BD bov is the most retarded invention I have ever seen. I drive the truck 1/4 mile maybe, get on it a bit and then lift, then the stupid thing stuck open so no boost... *** THAT NOISE
Well with no waste gate, il be keeping the BOV...you will just have to learn how to get back into the pedal with it....
