6.0 compounds pictures
kyle43335
OOhhh...I thought you had the engine pulled out to fab up your twins...
Installing that drain is one huge PITA....I can understand why you haven't "Started" to "Finish" it yet.
Take your time, it will be worth it in the end...no sense cutting any corners now.
They look great!
I had to use an adaptor in the upper oil pan plate, because to get the fitting in far enough to clear the lower oil pan, the fitting would hit the side of the block when I tried to insall it.
lol no the engine in the pics is a mock engine.
idk i might be changing some stuff up? esp cam,manifolds,pistons....
patrickke
Lexington,ky
His normal is the stage two..... He may have finally gotten someone to do the buy in.... to the op let me know if you need a price on a cam
