6.0 long crank
Dalton6.0
A while back I had my head gaskets done and also had some warren 190/stock injectors put in. Ever since then my truck has had cold starting issues. If the truck sits for a day or even over night it cranks for a long time, not matter how hot or cold it is outside, but worse if it's cold, and when it finally starts it puffs a cloud of white. After that doesn't matter how hot it is, it starts as it should. Icp shoots right up over 1000 ficm hold 48-49 volts. I'm thinking maybe an injector o ring or some other high pressure oil leak somewhere. Just wondering if anyone has had this same problem
Thank you.
Dalton6.0
Also when I let off the gas the truck doesn't come down to the normal idle speed for a few seconds, stays closer to 1000
I've ran 3 different custom tuners and it still does all of this on a stock tune.
Mesa, AZ
Is it full of oil? How are you parked when it happens? Is it at all fuel levels?
Dalton6.0
Yes it's full, all different ways mostly flat or a tiny bit of angle in my other driveway,and yes doesn't matter the fuel level
Mesa, AZ
What year truck? If its an 04 early or late?
Are the batteries ok? Is it cranking fairly fast or take a while to build to say, 150ish rpm?
Have you checked fuel pressure? Possible drain back issue?
Also could possiboy be glow plug related, any codes?
Dalton6.0
Batteries are new
Doesn't crank very fast, I feel like the starter is maybe a little messed up in some way, after all the work was done and they cranked the truck over a bunch to get it going the starter has always been slower. But turns the truck over ok just a tad slower than before, but has been like this for over 2 years now
I think fuel pressure is fine. just out a regulated return on the truck last weekend
No codes
Mesa, AZ
Ok, well this s getting a bit tougher then. It coukd be the starter drawing too much and not allowing full voltage for the glow plugs then. Or something in the accessory drive starting to lock up or something like that.
Not really leaning towards hi pressure issue as you say icp builds quick, and it starts no probkem hot.
Dalton6.0
My buddy was saying I could possibly be my ipr valve. I checks it at wot today and it was right around 2000
Idk what is normal though
Mesa, AZ
Wot while driving or in park/neutral? Ipr typically wont cause a hard start, it will cause surging at idle or a no start though. I have yet to see one cause what you are describing.
Dalton6.0
While driving. I have a reman starter I bought off eBay for $85 but am too scared to put it in and have it fail on me lol. Guess I'll be buying a new oem starter sometime soon
Dalton6.0
That still wouldn't describe the truck hanging around 1000rpms when I let off the gas though?
Dalton6.0
Truck sat for 15 hours. It was only 70 degrees but it took atleast 15 seconds of cranking for it to start this morning
Mesa, AZ
Are you letting the glow plug lamp go out prior to cranking? I know mine will not start if i dont wait. I have also had some in the shop that if i wait too long, they wont start till i cycle the key. It may be glow plug related, but without any codes its kinda tough to diagnose.
Also, try unplugging your icp sensor and see if it helps. That is kind of a shot in the dark though.
As for the idle thing, how many miles have you driven the tunes? I know as soon as i switch mine it hangs at about 900-950 but after letting everything relearn, it will come right down to normal idle.
Dalton6.0
Yes, I do. I've tried everything now in the mornings I cycle the key a few times then crank
I'll try that soon maybe sometime this weekend
And I run my tunes for weeks at a time, sometimes months and it never changes.
Just put a new starter in today and I'm gonna see if that helps at all but I doubt it will help much
Mesa, AZ
Ok man. Good luck. Sorry icouldnt be more help. Let me know how it goes though. If the starter doesnt help, ill see what else we cant try to figure out.
Mesa, AZ
Can you check your sync/ ficm sync. I wonder if you got a cam or crank sensor on its way out or some wiring that causes the excessive cranking.
